| Home > Help Needed / General Tech Chat > New engine- first start - LCB centre branch glowing red!!! | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
12th Jul, 2010 at 10:42:00pm
Guys, I finally got my new motor started this evening.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
12th Jul, 2010 at 10:42:56pm
Also, appologies for my arse in shot! Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
12th Jul, 2010 at 10:59:51pm
i had this on my original mini when i first got that going. it stopped after i stopped the airleak it had didnt adjust the fueling maybe that longshot but thats my experiance of it. Drives
12th Jul, 2010 at 11:01:42pm
Retarded ignition? On 26th Oct, 2004 TurboDave16v said:
12th Jul, 2010 at 11:05:51pm
OK cheers guys, so it's more likely to be lean / crazy ignition rather than something more arkward like cam timming? Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
13th Jul, 2010 at 05:41:06am
check your tappets are set properly, i once had one branch of a exhaust glowing, (on a motorbike, but still) and that turned out to be a exhaust valve nipping up and jamming open when things warmed up. Probably not the problem, but worth knowing!! And on the 7th day........... God created turbochargers! |
13th Jul, 2010 at 06:24:01am
Mine glows - I dont worry I seriously doubt it! |
13th Jul, 2010 at 07:45:12am
after 30 seconds at 2000rpm Paul?
13th Jul, 2010 at 10:53:39am
The exact jeting can only be determined on a rollers Prawn but if you use these as a base line it will be more than safe enough to take for a spin.
On 17th Feb, 2009 Rob H said:
13th Jul, 2010 at 11:24:13am
odd that its centre only, that could point to a valvetrain issue on 2-3
![]() 141 Posts Member #: 7891 Advanced Member Annapolis, MD USA |
13th Jul, 2010 at 11:45:42am
Definitely sounds lean as it is popping back through carb....although usually you need to be on the rich side for startup or the DCOE won't run. It probably would have stalled shortly if you tried to keep it going due to leaning out. Eric
16th Jul, 2010 at 12:55:01am
check fueling but like sprocket said i would put my money on ign to retarded always looking for them bigger bunches of bannanas |
16th Jul, 2010 at 10:24:39am
Third that on the ignition being to retarded. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Jul, 2010 at 11:08:39am
16th Jul, 2010 at 11:36:21am
If I’d known your pants preference I’d have worn them when you came round!
