Home > Help Needed / General Tech Chat > First time starting and running problems
Shaz_mini_Beast
Member #: 6887
well ive just installed my first turbo all went ok however when ive come to start it im having problems keeping it running
its as if once you rev it it runs out of petrol and stalls
ive set the fuel pressure to around 4psi using the boost gauge
starts fine and ticks over ok but the moment it starts to rev it cuts out or when you let go of the throttle it just stalls straight away
any ideas folks
also the boost gauge isnt giving even 2-3 psi boost but sounds to be whiring away
Got a bit of advice and...
it now starts and runs ticks over ok bit lumpy due to the 266 cam but still ok revs fine and will hold great at higher revs for 2-3 mins fine problem is when you let the throttle off it falls back down the rev range and stalls (even with the tickover set at 1500rpm). ive filled the dashpot with 15-40w oil. only other thing ive noticed is that when try to start it sounds very advanced almost firing before tdc. however timing hasnt been changed since it was running as a NA 1380 engine.
when i connected the lean out pipe into the inlet manifold pipe it started sucking petrol out of the carb and drowned the engine out so just blanked it but it ran better when left open
runs reasonably ok just stalls when drops from high revs to tickover
petrols not running out to the carb as the clear pipe never runs out. Also you can run at full throttle and vary the throttle for ages but when you rev it up and let the throttle just drop back to tickover it stalls and wont even re rev when revs get low.
Any ideas as its anoying me now
Any ideas
thanks
Shaz
Have you got a showing the carb plumbing?
The lean off pipe needs to either be connected to the pipe on the carb closest to the inlet manifold, or bothe ends block off.
Could be ignition related. What are you using for ignition? Turbo dizzy or megajolt etc?
philc
Member #: 1346
bromsgrove
i would suggest something along these lines, do you have a timing light
sounds like this to me.....`
Shaz_mini_Beast
Member #: 6887
Both ends are blocked off.
Im just using a standard dizzy at the moment to get it through mot, then megajolt is going on.
Yes i have a timing light (completely forgot that i had one), we are going to try this later this evening.
Thanks for the help guys
Shaz_mini_Beast
Member #: 6887
also, what do i have to change apart from the seals on a standard hiff44 to change it into a turbo carb?
