Home > Help Needed / General Tech Chat > smoking
turbo shane
Member #: 982
new zealand rotoura
right o boys i have a problem with my motor when i start it up ... it does everything it should starts up fine an runs well but always spits out alot of black smoke for a few mins and it goes away...but then somtimes while drivin it might smoke up again for a few seconds then it will go away... i am thinkin it could be the tapit seals or is it blow bye.... whats your guys thoughts..
my mini has a cold
worn valve guides?,
if you can park on a steepish hill,
facing upwards ,the oil should drain back down the pushrod holes and not be sitting over the guides
if the smoke is black then it very rich
if the carb needle is good (or right) check for warn choke seals
White/gray-about right
blue-oil
black-over fuel
someones blue could be nearer to the next mans black...lol
also do a compression check to see whats going off in there ?
whats the history of the motor ? starship miles ?
is it breating heavy through the breathers ?
is it a turbo engine with a T3?
turbo shane
Member #: 982
new zealand rotoura
i have just rebuilt the motor ... running a t25 turbo
my mini has a cold
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Could it be your choke seals in the carb?
On 7th Nov, 2008 Nic said:
naeJ
m
turbo shane
Member #: 982
new zealand rotoura
um what u mean about choke seals would that cause it to smoke like that at start up? for me i dont use the choke at all to start or run....
my mini has a cold
If the choke seals in a HIF carb leak, it enrichens the mixture even with the choke not in use, it also makes it very difficult to get the idle mixture right
Hmm, interesting you should say that. Van runs quite rich on a fairly lean needle and has a very rich idle.
We rebuilt the carb but to be fair that doesn't mean anything when "numptyspeed" has been at it.
On 15th Jul, 2010 John said:
"numptyspeed"
i like it*happy*
you say the engine is just built?, maybe just needs a bit of running in
How will running the engine in make the fuel mixture leaner?
it just does.....lol.
make sure you have the ignition timing set up correctley and then the mixture
has the valve stem seals been changed ?
i was thinking less about the colour of the smoke, more the fact its a new engine and smoking
turbo shane
Member #: 982
new zealand rotoura
valve stem seals was done before i rebuilt the motor ....but that was 4years ago ...an motor was just sitin before rebuild could they have dryd up an cracked? from time an heat? be workin on it on my day off so i guess i will find out...
my mini has a cold
if the compression is fine then i would go for the stem seals as they are 4 years old, and check the guides also.
i would uprate these to the viton stem seals used on the SPI models available from minispares.com
of all the engines I have ever built, not one of them has smoked beyond the first warm up after the cylinders have cleared
my first turbo engine smoked for about 4 miles, then was fine for the next 1000 or so
mowog
Member #: 6792
Needle and Seat in the float bowl
turbo shane
Member #: 982
new zealand rotoura
ok have taken the head off an found that the valve guides seals have gone ...as always the way rebuild the bottom end ... and didnt touch the head thinkin it was algood ... do it once do it rite....
my mini has a cold
Users viewing this thread: none. (+ 2 Guests)
