Home > Help Needed / General Tech Chat > Intercooler Ducting + Dump Valves
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Afternoon,
I have the 2wd cossie intercooler, Id like to have a scoop put in there for good airflow through the intercooler.
Ive seen the scoops on minis before, does anyone know where I can get one of these without buying the whole bonnet. Im sure they are smaller than the ones on the new mini, could anyone shed any light.
Also, Dump valve, Which works best I like the bailey design does anyone have a DV code which works best? I have the chatter at the moment which I prefer more, But I dont want to damage the turbo.
Thanks Chris
unless your running 25psi all day, i wouldnt worry,
could you not try and make a scoop?
or cut a hole or two?
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
I think I may end up cutin just 2 holes. I would like the scoop, Ill see if the guy that painted my car can make one I guess.
