Home > Help Needed / General Tech Chat > tee piece trick on a converted HIF 44
mini.cooper998
Member #: 3772
Wigan
can the T piece trick be done on a N/A Hif44 and if so do i just t from the plenum into the fuel breather and into the regulator
cheers folks
PS sorry for the post frenzy im a learner turbo ist
mini.cooper998
Member #: 3772
Wigan
anyone any idea
no point if its na
if its an na carb on a turbo'd engine, you are correct
I think he means using an NA carb on a turbo.
But yes get a pressure signal from the plenum and feed it into the floatbowl breather.
mini.cooper998
Member #: 3772
Wigan
i did chaps an N/A Carb on a turbo engine.
could explain my poor running issues
cheers
mini.cooper998
Member #: 3772
Wigan
sorted it.
works perfect now and runs like a dream just need to set up the fueling and the ignition timing and im away
good, dont go mad on the gas untill the fuel is sorted
