| Home > Help Needed / General Tech Chat > SHES GONE BANG!!!!!! | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
15th Jul, 2010 at 06:31:53pm
hey chaps, ive got a feeling it could be major but hopefully not!
'always keep a spare shot for a stray bird' |
15th Jul, 2010 at 06:36:56pm
15th Jul, 2010 at 06:45:37pm
10 psi dude, just fitted new actuator aswell! 'always keep a spare shot for a stray bird' |
15th Jul, 2010 at 07:09:25pm
Compression test, then head off. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Jul, 2010 at 07:18:09pm
melted piston plain and simple 9.85 @ 145mph
15th Jul, 2010 at 07:37:41pm
you've fucked it dude:(
15th Jul, 2010 at 07:41:07pm
As above. comp test worth it just in case you've lost the rings and cant see with the head off. If something is worth doing, it's worth doing half of. |
15th Jul, 2010 at 07:42:09pm
![]() 428 Posts Member #: 39 Senior Member Bristol |
15th Jul, 2010 at 07:54:00pm
bugger, an experience I never want. |
15th Jul, 2010 at 08:03:55pm
when you get some time mate let me know and i will help where i can. Edited by MarkGTT on 15th Jul, 2010. |
15th Jul, 2010 at 08:16:38pm
Bad news mate, comp test as everyone says. Hope its not too grenaded. |
15th Jul, 2010 at 08:18:34pm
pretty much confirming my thoughts guys thanks.
15th Jul, 2010 at 11:10:13pm
Tis fooked tis that. oil out the breathers, regular missfire with smoke, is fooked piston On 26th Oct, 2004 TurboDave16v said:
15th Jul, 2010 at 11:27:22pm
mine did the exact same, but mine was due to a hole being created in the head then water was being sucked into the cylinders and more than likely down past the rings into the oil.. take all the plugs out and see if theres any water in them? then if not like people have said you will have made a hole somewhere |
16th Jul, 2010 at 10:32:21am
ring lands have shat themselves,
16th Jul, 2010 at 12:16:24pm
yes there are mega's benross, is this a common problem with these pistons then??? 'always keep a spare shot for a stray bird' |
17th Jul, 2010 at 07:55:21pm
Im afraid shane, hoggy amongst others have had ring land failures with these pistons. -MINI CLUBMAN 1380 TURBO- |
