Home > Introduce Yourself > Hello Turbominis!
miniJJ
Member #: 8989
Newcastle Upon Tyne
Hi, I'm JJ and this is my mini:
Currently a 998 with a stage one kit and megajolt ignition. (really proud of my megajolt install!) However, as a summer project I've decided to build a 998 t2 turbo engine, and maybe fit it next year once the insurance is due for renewal.
Hopefully I can pick up a complete 998 engine in the next few weeks, strip it down and rebuild from there. Initial thoughts are:
998 A+ block, rebore to suitable next size, pocketed, suitable pistons?
12g940 head, chambers opened out to reduce CR
reground crank, balance along with rods? centre main strap.
duplex timing chain
cam? need advice, na MG metro or standard 998
metro turbo inlet and exhaust manifolds, metro turbo carb
clutch? not sure which to go with
t2 turbo, metro manifold adapted to suit.
small intercooler
unusure on gearbox spec, not sure what power this spec could produce.
But enough of that, just popping in to say hi! Cheers, JJ
Edited by miniJJ on 15th Jul, 2010.
1380rich
Member #: 4755
warwickshire
evening and welcome *happy*
hi mate and welcome, the search is your new friend.
spanner1981
Member #: 8970
shropshire
welcome
Hello and welcome.
Your mini looks nice. engine sounds like a fairy descent spec
miniJJ
Member #: 8989
Newcastle Upon Tyne
Thanks guys, I've been searching the forum for a few days now, as nearly every question I've thought of has been asked and answered already. :)
Looking forward to starting the build!
MarkGTT
Member #: 1194
Shropshire.
Good luck with the new build - welcome to TM.
Welcome to TM!!!
Carl S
Member #: 1761
Stalker
Welcome to TM JJ.
Welcome to TM!
Welcome to TM.
In answer to your questions my personal thoughts are.
N/A MG Metro Cam
Rebuilt Helical Box
X-Pin Diff
Helical Drops
Pre-Verto clutch with orange spring or an RTS ckutch (you'll have to do a search about the latter *wink* )
Edited by John on 16th Jul, 2010.
miniJJ
Member #: 8989
Newcastle Upon Tyne
Fantastic! that cleared up the few things I was unsure on, just need to do a little more searching before I upset my wallet.
Cheers guys!
smither07
Member #: 8990
Houston, Texas
WELCOME, hope we enjoy here. :)
PC to Ipod Transfer - Selling Antique Rings
longy
Member #: 2727
Bicester
Howdie
1972 998 TURBO SLEEPER
Its worth looking for a 12G295 head, as you won't need to pocket the block.
miniJJ
Member #: 8989
Newcastle Upon Tyne
Thanks guys, I thought about a 12g295, but they are getting harder to get hold of and are quite alot more expensive than a 12g940. Pocketing the block doesn't seem to bad to me.
Thanks
