Home > Help Needed / General Tech Chat > Removing T3 Turbo??????
miniman03
Member #: 7642
Gillingham, kent
Hi, i have a metro turbo lump in my mini but the other day it started smoking blue a bit on idle after rolling road. Im thinking its possible more turbo side? if so just wondering if it is esiaer to remove the turbo whilst engine is in or would it be an engine out jobby???
advices please, much appreciated people.
If you have an original steel oil feed and dont want to break it, removal can be tricky.
If you dont care about damaging it, removal is very easy. I certainly would not be removing the engine.
In otherwords, replace the steel oil feed with a braided line while you're doing the job.
miniman03
Member #: 7642
Gillingham, kent
cheers for that, makes sense really, can i buy the braided feed pipe anywhere or is it a special modification to be bought somewhere else?
Kean
Member #: 341
aka T2clubby
South Staffs
Avonbar should be able to sort you out.
Or Minispares.
how do you know its the turbo?
there was a link in the ebay section to what looked like a well priced braided oil feed kit
miniman03
Member #: 7642
Gillingham, kent
Rubicon: i had all the compression tests done and they were very strong so the bloke at rolling road said it seems to be more turbo side than engine. it pulls fine and producing 103 BHP but could be a seal gone in turbo i think.
Apbellamy: cheers for that ill look up and order one. cheers fellas
