| Home > Help Needed / General Tech Chat > Ignition fault, megajolt related | |||||||
17th Jul, 2010 at 05:24:46pm
I,m about to set fire to the A35 !!
![]() 7 Posts Member #: 8989 Junior Member Newcastle Upon Tyne |
17th Jul, 2010 at 05:42:00pm
I had this, turned out my sensor bracket was flexing at a certain rev range (for you 4000 rpm) due to a harmonic or something. This causes the mj to lose signal before regaining it and the unburnt fuel ignites in the exhaust.
17th Jul, 2010 at 05:53:07pm
sesnor bracket (as above)
Edited by evolotion on 17th Jul, 2010. turbo 16v k-series 11.9@118.9 :)
17th Jul, 2010 at 06:22:32pm
What air gap have you got the sensor set at?
AlexF |
17th Jul, 2010 at 06:36:55pm
Thanks for the ideas.The sensor bracket is a welded up item, never given a problem before.Air gap may be a little karger than necessary, but again, has worked so far. Will re-check both these aspects, but I am favouring the VR sensor wiring being affected by external; noise, so will re -route that too.Maybe the bolt securing the sensor to my bracket has loosened ?
17th Jul, 2010 at 08:45:44pm
Check your earths as well I had a similar problem in the past.
17th Jul, 2010 at 09:37:47pm
had similar check the earth's and the wire to the VR sensor is well shielded. I run a supercharger and I don't care the TB is on the wrong side.
18th Jul, 2010 at 03:38:17pm
i would have spotted you if i was there, i packed up and left on saterday night due to a cracked liner! turbo 16v k-series 11.9@118.9 :)
18th Jul, 2010 at 03:53:24pm
Well, it turned out to be dodgy wiring -I think.
.. again this is "controlled" by engine vibration.
