| Home > Help Needed / General Tech Chat > runing problems + smoke | |||||||
67 Posts Member #: 8744 Advanced Member |
21st Jul, 2010 at 08:33:29pm
hi i have just taken my turbo mini out after having the carb rebuilt and rolling roaded and i seem to have a lot of blue smoke coming from the exhaust when pulling off, and when i get going the car seems to jump around the rev range stalling and starting again, any one got any idea thanks mike |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
21st Jul, 2010 at 10:39:31pm
Blue smoke tends to mean that you are burning oil. Does it do it all the time hot or cold?
22nd Jul, 2010 at 10:38:23am
On 21st Jul, 2010 haimesyboi said:
Blue smoke tends to mean that you are burning oil. Does it do it all the time hot or cold? A compression test would be a good place to start, repeated with a squirt of oil to check the rings. Also pull off the plenum pipe and check for deposits in there. Who did the carb work? CORRECT! if the engine didnt burn oil before you problem lies with an over rich mixture ..... indused boost bog ...... correct the mixture problem hope this helps
22nd Jul, 2010 at 05:28:22pm
i had the work done at sleaford mini centre it seemed fine when i picked it up but then its only 3 miles away, but took it out the day after and thats when i noticed the smoke and the rev surges |
22nd Jul, 2010 at 09:26:36pm
most likley over fueling .... badly!! set up
23rd Jul, 2010 at 10:31:36am
Are you sure the smoke is blue and not black, if it is black and overfueling enough to effect your running like this you should be able to smell the fuel. |
23rd Jul, 2010 at 04:44:03pm
the mini smells of fuel atm anyway because the carb leaked thats why it went in for a rebuild then i fought while its in there stick it on the rollers to check it for another show season! mike |
