Home > Help Needed / General Tech Chat > Clutch hydraulic problems
Thelooneytuner
Member #: 8864
Hi guys, been having a leak on my old slave so I changed it yesterday for a new one. Swapped it over no problems, bled it through as per instructions in Haynes.
I took it for a spin and the pedal has quite a high resistance.
Re bled the clutch again and I'm still having problems.
The pedal has high resistance
It seems to slowly return back to the top
And also the biting point has come right to the top of the pedal!
I didn't have these problems before just had to top up every other day!
It's a verto by the way
Russ
could be the rubber hose, thev can colapse causing a restriction.
are you certain it's blead properly? we had loads of trouble bleeding up the slave cylinder in the metro van
Yep basically it was aftermarket tat and when mounted on the transfer case it wouldn't bleed correctly. Ended up taking it off the transfer housing and holding it with the bleed nipple vertical and bleeding it that way.
the best way I have found of bleeding is to stick a clear pipe on the bleed nipple and stick it back into the master cyl, you can then open the nipple a fair way and pump the fluid through at a fair rate.
The clever mexican has given me a new trick *smiley*
lol,
its worth mentioning that as you pump there will be some tiny bubbles that get sucked in through the bleed nipple thread as you release the pedal, you can ignore these, or you can stick some grease on the tread of the bleed nipple to stop it.
More tricks for my act.
Thelooneytuner
Member #: 8864
Thanks, I bled it like 4 times and tested it after each go!
I shall have another go with these tips and see how it goes, it's a non gen but it was needed sharply as clutch fluid was pissing out of the front of the old one! Needed topping up daily!
Failing that I may try the hose!
I'll give it a go tomorrow
Russ
haimesyboi
Member #: 5702
Cornwall
Nice one Joe!
metroturbo
Member #: 989
North Yorkshire
I couldn't get mine to bleed in situ, so I reached for the easi-bleed and the job was done in seconds.
+1 for eezibleed. its been great, so the wife doesn't moan about pumping the pedal
Mr Joshua
Member #: 1954
Luton Bedfordshire
Ghetto!*surprised*
Own the day
I've also opted for the ezi-bleed thingy'.
It really does work well and as above, you don't need a helper.
