Home > Help Needed / General Tech Chat > What size copper crush washer?
gutted
Member #: 645
Derby
Anyone know what size crush washer I need for the turbocharger oil feed banjo union? This is for a bog standard Metro turbo. There are 2 different sizes on each banjo union - small and large. I've got several of the smaller ones (Rover part number is ADU 6847) but I don't have any of the larger ones (ADU 6848). I guess a generic copper sealing washer (crush washer?) would do the trick, but I don't know the exact size.
Anyone know the correct size for these things? Or whether it's imperial or metric, so I can measure it?
Cheers!
Dan.
Metro turbo owner
the banjo bolt on the block end is 5/8 unf. The turbo end is 3/8 unf
Dan.
i picked a pack up from my local motor factors about 3 quid, there was 5 or 6 different sizes, one of them fitted nicely
gutted
Member #: 645
Derby
Cool - thanks for your help. I'll definitely check local motor factors as a bag of them can't hurt. I've managed to source one new one, so will take that along with me to (hopefully) make sure I get at least one of the right size in a job lot. Other than that, I'll get eBaying for a job lot of the correct size.
Cheer again for that.
Dan.
Metro turbo owner
