| Home > Help Needed / General Tech Chat > spark plugs | |||||||
26th Jul, 2010 at 09:01:19pm
Evening gents
26th Jul, 2010 at 09:18:55pm
NGK BPR6ES or BPR7ES the R is for Resistor On 26th Oct, 2004 TurboDave16v said:
90 Posts Member #: 7555 Advanced Member |
26th Jul, 2010 at 09:19:49pm
You need resistor plugs with the MegaJolt |
26th Jul, 2010 at 09:20:18pm
Since running megajolt I have used NGK BKR7EIX
Edited by gr4h4m on 26th Jul, 2010. I run a supercharger and I don't care the TB is on the wrong side.
26th Jul, 2010 at 09:52:20pm
I use std ngk bpr6es's |
26th Jul, 2010 at 10:02:04pm
rick if the boost your running is over 16 psi i would go 2 plug grades down colder from standard from champion N9Y
26th Jul, 2010 at 10:03:52pm
Running NGK 7's here, up to 20psi, no issues. |
26th Jul, 2010 at 10:13:36pm
I'm using ngk 8's. Should I go for 7's? In the 13's at last!.. Just |
26th Jul, 2010 at 10:46:03pm
Chears guys, i was running 7's when it was running years ago but sure ive got som 9's somwhere aswell.
28th Jul, 2010 at 07:06:53pm
Im i right in thinking i need 35thou with the mj rather than 25 thou
28th Jul, 2010 at 09:22:54pm
On 26th Jul, 2010 Nic said:
I use std ngk bpr6es's http://www.twin-turbo.co.uk
28th Jul, 2010 at 09:57:49pm
I tried 7's but it seems to bog down at low revs.
Edited by Nic on 28th Jul, 2010. |
28th Jul, 2010 at 10:03:48pm
I use std ngk bpr6es's +1 |
28th Jul, 2010 at 10:04:58pm
If it works with 6's it works with 6's, so stick with it. I am just surprised that they have not overheated. http://www.twin-turbo.co.uk
