Home > Beginners Tech > MJ Coil Pack power feed
Simon
Member #: 1865
Norwich, Norfolk
Where are people getting their power feed to the MJ box and the Coil Pack from?
I have one of those big red battery cut off swicthes on my dash so wired my power for the above to that switch. This was fine until of course when you turn off the ignition the car still runs, and even killing the power on the cut off switch the car continues to run because the altenator is sending power back up the line.
Where should I be getting my power feed from so that killing the ignition will actually stop the engine.
Midas
Member #: 7555
Ignition switched live works on mine.
Simon
Member #: 1865
Norwich, Norfolk
what colour is that and at what point in the loom have you T'd into?
pm sent
metroturbo
Member #: 989
North Yorkshire
I used the wiring from the original coil.
I think mine is from the switched live on the fuse box..
this helped me lots with this hope it helps
simon
Edited by madmk1 on 26th Jul, 2010.
Simon
Member #: 1865
Norwich, Norfolk
thanks for the help guys, i now have a car that isnt impossible to turn off!
because you have a constant live to the coil pack?
