| Home > Help Needed / General Tech Chat > Few Quick Questions - Engine Building | |||||||
![]() 127 Posts Member #: 1871 Advanced Member Chesterfield, Derbyshire |
28th Jul, 2010 at 07:42:45pm
I have just finished stripping my engine down for cleaning and rebuilding and have a few quick questions.
Edited by Mattlad on 28th Jul, 2010. |
28th Jul, 2010 at 07:47:17pm
Crank looks fucked to me. Rings deffo need replacing, I've tried re-using and it smoked like nothing you've seen before!
28th Jul, 2010 at 07:52:38pm
Thats what I was affraid of, with the crank and piston rings!
28th Jul, 2010 at 07:57:30pm
On 28th Jul, 2010 Brmatt said:
And now the most important part, what colour red or green? I would have thought the fact the crank you are thinking of using is totally fucked was somewhat more important than the colour of the car.... How on earth did you manage to do that much damage ??? EDIT - looking at the photo again it looks like you used an angle grinder and an oxyacetylene torch to take the flywheel off rather than the usual (non-damaging) puller Edited by Rod S on 28th Jul, 2010. Schrödinger's cat - so which one am I ??? |
28th Jul, 2010 at 08:02:10pm
Sorry, i meant what colour shall I paint the engine.
28th Jul, 2010 at 08:03:13pm
.. Edited by Sprocket on 28th Jul, 2010. On 26th Oct, 2004 TurboDave16v said:
28th Jul, 2010 at 08:03:44pm
Secondly, do you think this crank can be used or is it F@?ked, the engine has been lying around for a while and the end of the crank has be bashed about abit!
Im not sure how to take this Is it a wind up or, just some one that is not mechanically minded ?
Mind you, nothing that a bit of JB weld wont fix On 26th Oct, 2004 TurboDave16v said:
28th Jul, 2010 at 08:14:57pm
I've never seen a crank like that in my life, nothing more than a paperweight now. |
28th Jul, 2010 at 08:15:05pm
Sorry, i meant what colour shall I paint the engine. I bought the engine off a friend of a friend for £50, think its been lying about on a farm for a while, but it is a genuine metro turbo engine I think "was" a genuine metro turbo engine... would be a better description. Seriously, I would try to source a crank that has had the flywheel removed by someone who knows what they are doing.... Schrödinger's cat - so which one am I ??? |
28th Jul, 2010 at 08:23:24pm
At least ive still got some decencent bit, so not a total loss,
28th Jul, 2010 at 08:46:56pm
Before you spend any money, take the block to a machine shop and get the bores measured properly and the head gasket faces checked for flatness. Going by the state of the crank, the engine had a hard life. So the bores may already be badly worn and require a rebore and new pistons etc.
Edited by apbellamy on 28th Jul, 2010. On 11th Feb, 2015 robert said:
![]() 558 Posts Member #: 8143 Post Whore London |
28th Jul, 2010 at 08:56:09pm
Did you take the flywheel off the engine or was it already off?
784 Posts Member #: 912 Post Whore North Yorkshire |
28th Jul, 2010 at 09:03:31pm
Contact Fastcarl on here.
I drill holes in everything..! |
28th Jul, 2010 at 09:04:28pm
Is this another one of those 'i poured sand into the inlet to port my engine' type, joke threads?
In the 13's at last!.. Just |
28th Jul, 2010 at 10:11:48pm
If the bores are fine and the rings were sealing. There is absolutely no need to replace the rings. In fact, if the current ones are sealing on a factory hone etc, it would be best to leave them as is.
28th Jul, 2010 at 10:15:12pm
On 28th Jul, 2010 Si P said:
Contact Fastcarl on here. I recon that crank can be repaired but you will lose the cut out for the c washer. Worth a go if its the only crank you have. Si Its scrap On 26th Oct, 2004 TurboDave16v said:
28th Jul, 2010 at 11:54:22pm
Was that in miniworld back in 2001
29th Jul, 2010 at 12:23:22pm
On 28th Jul, 2010 dischub said:
Did you take the flywheel off the engine or was it already off? There was no flywheel on the engine when I got it. On 28th Jul, 2010 stevieturbo said:
If the bores are fine and the rings were sealing. There is absolutely no need to replace the rings. In fact, if the current ones are sealing on a factory hone etc, it would be best to leave them as is. The rings look fine, and so do the bores On 28th Jul, 2010 nic said:
Was that in miniworld back in 2001 Yeah it was in May 2001, I really regret not looking after it and having to scrap it, goin for the same look for my next one though |
29th Jul, 2010 at 12:30:16pm
Can you see 0.010" of wear in the bores?
29th Jul, 2010 at 12:41:09pm
The Bores are spot on TBH
29th Jul, 2010 at 12:53:52pm
This has got to be a joke, I can't see how anyone could possibly think that crank is usable! Edited by matty on 29th Jul, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Jul, 2010 at 01:27:55pm
as a door stop yes Own the day
