| Home > Technical Chat > Metro turbo engine without the turbo | ||||||
2 Posts Member #: 9011 Junior Member |
29th Jul, 2010 at 06:56:32pm
im trying to understand this engine and figure out if its worthwhile..
29th Jul, 2010 at 07:01:36pm
The 1275 metro turbo engine is a standard 1275 block, with uprated pistons, in some cases a hardened crank, uprated oil pump, standard cam, standard valve sizes in the head and sodium filled valve guides.
Edited by apbellamy on 29th Jul, 2010. On 11th Feb, 2015 robert said:
29th Jul, 2010 at 07:03:44pm
On 29th Jul, 2010 asmith88 said:
does it still have the mg camshaft from the 1300? No, it has a standard 1275 camshaft On 29th Jul, 2010 asmith88 said:
is the engine capacity 1300? standard was 1275cc On 29th Jul, 2010 asmith88 said:
will it have any power increases from the standard 1275? No. On 29th Jul, 2010 asmith88 said:
any downsides? Well you could run higher CR than the standard turbo CR, but at 9.3:1 it's not that low. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
29th Jul, 2010 at 07:22:09pm
ok, so its pointless really unless the turbo is on it? |
29th Jul, 2010 at 08:04:17pm
It will be slower than a MG Metro non turbo engine, if both are in good condition, if that is what you are asking.
31st Jul, 2010 at 11:05:10am
The heads are quite different between the turbo and the MG Metro.
Own the day
31st Jul, 2010 at 01:02:46pm
Not strictly true. The early NA MG Metro heads had the larger 35.7mm inlet, but the later unleaded MG heads were downgraded to the smaller 33.3mm inlet. |
