| Home > Help Needed / General Tech Chat > Mini wheel clearance with orginal steering rack? | |||||||
17 Posts Member #: 8741 Member |
29th Jul, 2010 at 08:45:13pm
Have a quick question does the standard steering rack work ok with a mini with 13 by 8 wheels with arches cut correctly and sportpack arches fitted?.Ive heard that i might need to get a different rack which doesnt allow as much lock?. Also totaly different topic I am spraying my car vxr arden blue would you paint the roof white?, Silver?, or same colur as the rest of car?. cheers for any help in advance. |
29th Jul, 2010 at 09:31:59pm
roof is personal choice imo, i like the same as the body,
Yes i moved to the darkside |
261 Posts Member #: 713 Senior Member Western Australia |
30th Jul, 2010 at 12:22:58am
You can buy plastic spacers to stop the rack from being able to turn too far. They were fitted as an original part on 13" wheeled mokes as I remember. On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
30th Jul, 2010 at 12:52:39am
coulor is up to you...
30th Jul, 2010 at 08:07:07am
I have 13 x 5.5 and they are fine, but I would think that 8s could be more of a problem. It also depends on the offset of the wheels.
http://www.twin-turbo.co.uk
30th Jul, 2010 at 08:15:00am
8x13 will rub the inner arch, 100%. You therefore have two options.
30th Jul, 2010 at 08:55:07am
On 30th Jul, 2010 wil_h said:
8x13 will rub the inner arch, 100%. You therefore have two options. 1) Buy an MPI rack 2) buy some of these I fitted some of these as I had Minispares tie rods and the caliper pipes kept wiping out on the 6 pots - I found that i could not get round the hairpin at the Pestalozzi hillclimb see image of hairpin
13 inch are not the best on a mini anyway for the road but 8x13s are just a waste of time ( I ran 13s for a while btw) Edited by Scruffy on 30th Jul, 2010. On 5th Sep, 2011 Vegard said:
30th Jul, 2010 at 09:16:40am
They do reduce the lock massively, but never had to do a 3-point turn on a hillclimb yet.
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
30th Jul, 2010 at 09:42:22am
13 inch are not the best on a mini anyway for the road but 8x13s are just a waste of time ( I ran 13s for a while btw) On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
