| Home > General Chat > Mamba 10" x 6" - replicas - copies - what are they | |||||||
30th Jul, 2010 at 05:47:33pm
Earlier this year, when the snow was thick on the ground, I picked up three supposed Mambas from eBay fairly local to me.
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
30th Jul, 2010 at 06:32:08pm
They are copys made by MWS in the 90's, as far as I know.
[X] nail here for new monitor |
30th Jul, 2010 at 06:43:15pm
Thanks Asphalt, that begins to make sense.
30th Jul, 2010 at 06:51:29pm
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? On 26th Oct, 2004 TurboDave16v said:
30th Jul, 2010 at 07:00:00pm
On 30th Jul, 2010 Sprocket said:
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? Because there are some "Chinese" aftermarket alloys that do..... They do it by a large offset and large internal clearances. Looking at these strange ones I've got, they both have large internal clearances (look at the photos of the well from the inside) and a large offset (not qute so obvious from the photos) and they very nearly did fit over standard 8.4" discs. I was just wondering if that is why these "strange" ones (they are not real Mambas) had been made. But although close, there isn't quite enough clearance for 8.4" I'm still intruiged as to why I haven't seen these before though.... Schrödinger's cat - so which one am I ??? |
30th Jul, 2010 at 07:02:24pm
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? Because:
212 Posts Member #: 8109 Senior Member Suffolk |
30th Jul, 2010 at 07:14:15pm
surly its dangerous to run them that wide sones in disc ? Drop A Gear An Floor It |
30th Jul, 2010 at 07:45:42pm
I wouldn't be worried about stones in the disks, but that just look wrong, hello torquesteer! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
30th Jul, 2010 at 07:46:14pm
An incomplete set ! Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
30th Jul, 2010 at 08:30:17pm
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? Colin, to put a bit more perspective into this.... I didn't. I've seen the Chinese ones on eBay that claim to fit but it's obvious they use a very large offset to achieve it. Also I wondered when I got the tyres off these ebay purchases, was whether that was what they were trying to achieve... The postion of the well makes for much more clearance inside and the offset is large. I tried it - they don't fit ![]() ![]()
Just an experiment.
Edited by Rod S on 30th Jul, 2010. Schrödinger's cat - so which one am I ??? |
30th Jul, 2010 at 08:34:27pm
Could you machine the inside of the wheel a little to make them fit or are they massively too small?? On 11th Feb, 2015 robert said:
30th Jul, 2010 at 08:44:06pm
Andy, it's not a problem...
297 Posts Member #: 2276 Senior Member sheffield / derby |
30th Jul, 2010 at 08:58:37pm
as stated above, maybe the same/similar as these ??
Edited by 998turbomini25 on 30th Jul, 2010. |
30th Jul, 2010 at 09:35:12pm
![]() Well those discs dont actualy fit inside the wheel now do they
Rod, its OK mate as the above reply was what I was expecting
30th Jul, 2010 at 10:32:34pm
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? Carl will make you a 10" wheel that will fit over 8.4" discs with the standard 2 pot caliper.
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
1st Aug, 2010 at 03:30:03pm
I have these mambas on my car.
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
2nd Aug, 2010 at 07:29:13am
what about 7.9s? On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
2nd Aug, 2010 at 09:23:22am
![]() ![]() From a technical point of view that's correct
2nd Aug, 2010 at 09:29:05am
I have no idea how you could expect an 8.4" disc to fit under any 10" rim? If we're getting all anal about things - the disk will fit fine, just not with a calliper attached to the hub. On 11th Feb, 2015 robert said:
2nd Aug, 2010 at 10:37:32am
Mathematically it should be possible with a purpose designed wheel and caliper, 8.4" to 10" is 0.8" on radius or 20mm in real units. The wheel probably only needs to be 4mm thick at that point leaving 16mm for disc to caliper bridge clearance, caliper bridge thickness and caliper bridge to wheel clearance. Say 2mm for each of the clearances, I'm sure a caliper bridge for a single piston caliper could be made 12mm thick in a high strength material (not aluminium).... They aren't much thicker than 12mm on the standard one.
