Home > Help Needed / General Tech Chat > Running rich???
turbo22
Member #: 3684
wisborough green west sussex
Right i am yet to get the mini set up correctly as i am still in the build process but i have something im sure you chaps can help me on.
I know it is warm weather at the moment but my mini starts first time from cold with no choke at all and seems to smoke a little bit,does this mean its running too rich???.
I know i have to have it set up right but i would like to get it as close as i can before hand to prevent any damage.
cheers
rich is better than lean. Water colour is the smoke? Blue/grey/black?
turbo22
Member #: 3684
I would say its closer to grey but hard to tell as its in a barn. It also smells a bit fuely but i guess thats standard.
dont go too rich, it could wet the bore walls, not good atall , grey smoke would indicate rich,
turbo22
Member #: 3684
Thats what i thought, right ill try and adjust the mixture screw a little. What is the ideal colour?
no smoke is perfect!
turbo22
Member #: 3684
That was obvious DOH, thanks guys ill try and sort it now. It only seems to be on start when its running it seems to clear.
the engine can choke up being just run in the garage and not take for a run out ............
turbo22
Member #: 3684
ok thanks steve, im avoiding running it as much as i can until its finished and can be sorted and set right.
a great investment and a must realy would be an AEM lambda gauge .....these have well come down in price on ebay.co.uk
turbo22
Member #: 3684
ill look now thanks again.
