| Home > Help Needed / General Tech Chat > Fuel pressure problem | |||||||
12th Feb, 2005 at 12:56:48pm
Having fitted a gunsons lo-guage to carb fuel inlet hose to check fuel pressure, i can only get a constant reading at 2.5-3psi. When the regulator is adjusted to anything over this the fuel pressure is very erratic. I have replaced the diaphram in the regulator and cant see anything else on them that can cause a problem, there are no restriction in my return line and i run 8mm feed and 10mm return. I have two 8mm outlets from tank, these then pass through filters and then connect to a t-piece with a 12mm outlet to supply pump. Both filters seem to have air bubbles in them- is this normal?? Also when the fuel pressure is going mad the fuel returning to the tank surges back in rather than a nice constant flow. Any ideas?? -MINI CLUBMAN 1380 TURBO- |
12th Feb, 2005 at 02:24:18pm
sounds like the pump to me if your sure everything else is fine.
Edited by iain on 12th Feb, 2005. |
12th Feb, 2005 at 03:01:41pm
Cheers iain
12th Feb, 2005 at 03:19:14pm
according to a dude who sells em on ebay the MG-Rover part number is AUU1649
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
12th Feb, 2005 at 03:57:44pm
Could be the filters. If they are a bit blocked up they could cause you trouble. You can also get fuel vapour entering your pump if they aint flowing to well.
12th Feb, 2005 at 06:28:51pm
ive got the new bosch number somewhere. bascially the rover part that lucas rebadged then sold to rover! lol!
13th Feb, 2005 at 05:18:24pm
Got this problem sorted now, air in the fuel line from regulator to guage. I held the guage below the level of the regulator, tapped the regulator until all the air escaped and got me constant fuel pressure back. Surprised no one else has had this happen before but it was probably me being a dip s*it.
13th Feb, 2005 at 05:28:57pm
what about me for supplying you a spare pump!!!!!!!!!!!! lol.
421 Posts Member #: 245 Senior Member |
14th Feb, 2005 at 05:39:57pm
at least you saved some money not having to buy a new pump, |
