| Home > Help Needed / General Tech Chat > Votage Stabalizer/regulator | |||||||
4th Aug, 2010 at 12:34:53am
I need to fit one in order to run my oil temperature gauge. As a cheat I was going to use the one off of the back of my single binacle clock ( the one that feeds the fuel and water temp gauge).
Own the day
4th Aug, 2010 at 08:35:09am
It is supposed to happen.....
Edited by Rod S on 4th Aug, 2010. Schrödinger's cat - so which one am I ??? |
72 Posts Member #: 6792 Advanced Member |
5th Aug, 2010 at 10:35:02pm
With the original type voltage regulator, you won't be able to measure the output voltage with a digital type multimeter, if that was what you were using.
6th Aug, 2010 at 12:00:48am
I can do you a solid 10v 2A reg in the original housing On 28th Aug, 2011 Kean said:
6th Aug, 2010 at 03:08:24pm
My gauge is a smiths oil temp gauge and I was useing a moving coil metre. Own the day
6th Aug, 2010 at 03:09:08pm
I may take you up on that On 6th Aug, 2010 Joe C said:
I can do you a solid 10v 2A reg in the original housing Own the day
6th Aug, 2010 at 03:09:14pm
