| Home > Help Needed / General Tech Chat > Water pump pulleys, large or small preferable? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
4th Aug, 2010 at 08:13:10am
chaps, I'm about to start a new front mounted rad setup, and whilst it's all off, I was wondering what's the preference on water pump pulleys.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
5th Aug, 2010 at 11:09:13am
the smaller pump will make more flow for the same RPMs than a bigger water pump pully .......... i would stick with that
72 Posts Member #: 6792 Advanced Member |
5th Aug, 2010 at 10:30:07pm
On 4th Aug, 2010 Prawn said:
chaps, I'm about to start a new front mounted rad setup, and whilst it's all off, I was wondering what's the preference on water pump pulleys. I'm currently running the smaller pulley due to my previous head being skimmed so much, but the engine runs very hot with a minispares 2 core rad. Is it preferable to run the larger pulley? it's a high revving n/a 1380 motor (8k rev limit) if that makes any odds. Would the pump be cavitating at high revs with the small pulley? Cheers Nick If your running with the by-pass between the head and pump, that will cause cavitation and a bigger pulley would help. |
5th Aug, 2010 at 11:29:54pm
Road car, small. Race car, big. On 13th Jul, 2012 Ben H said:
5th Aug, 2010 at 11:56:59pm
I'm with vegards thinking,
