Home > Help Needed / General Tech Chat > Clutch won't disengage
MrOz
Member #: 5007
Crazyhill, Livi
Finally got time to uprate the MPI clutch, thought it went ok - thanks to Sprockets instructions (nice one!).
The pedal is solid - getting maybe about 1 to 2" of travel then nowt. I first thought it was the throw out, but I've backed the nut right off and it's the same.
If I put the Mini in gear, then turn it over with the clutch down - it drives, there is a squeal and the smell of burning clutch.
Do you think it is likely to be the thrust bearing - is it possible to install it the wrong way round?
I'm gonna have a look at it after dinner, MrsOz is not impressed.
Could have done with the Mini on the road for tomorrow - typical, eh?
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
MrOz
Member #: 5007
Crazyhill, Livi
Yes is the answer - I'm such a cock.
That would be the liner in the top hat melting......
Anyone got a spare top hat???
yes. drop me a PM with your name and address and I'll drop one in the post tomorrow.
EDIT: Do you just want the top hat or the bearing on the end of the plunger as well?
Edited by apbellamy on 6th Aug, 2010.
MrOz
Member #: 5007
Crazyhill, Livi
*Clapping*
PM'd.
Nice one!!!
