| Home > Help Needed / General Tech Chat > Engine bay photo | |||||||
6th Aug, 2010 at 07:41:07pm
Has anybody got a top down shot of a mini engine bay. In particular down the back of the transfer case, showing the gap between that and the subframe
Edited by apbellamy on 6th Aug, 2010. On 11th Feb, 2015 robert said:
6th Aug, 2010 at 07:59:19pm
Not until now.....
Edited by Rod S on 6th Aug, 2010. Schrödinger's cat - so which one am I ??? |
6th Aug, 2010 at 08:16:40pm
Thanks Rod.
6th Aug, 2010 at 08:32:44pm
OK, in that case the horizontal flange of the subframe runs through the middle of the "triangle" of the Metro mounting bosses (mines an earlier A+ housing so isn't drilled/tapped for the metro mount but the bosses are cast anyway).
6th Aug, 2010 at 08:40:02pm
I guess it's wait and see how well it fits when I eventually build the mule engine and butcher my subframe.
6th Aug, 2010 at 08:54:33pm
If the triangle of the mounting bosses is equilateral you could fit it in any of three positions but only the original position will give you a horizontal/vertical boss/bolt.
6th Aug, 2010 at 09:27:20pm
This is the pic:
