Home > Help Needed / General Tech Chat > push rods
pete
Member #: 275
bonie scotland
lookiing for a longer set of push rods, 5mm longer suitable for 1275, my rocker set up is. s rockers with of set offset bushes, steel post to match, i no you can get longer tappets ajusters? just trying to get best rocker ratio.............
turbo hogster
Member #: 178
stowmaket suffolk
longer adjusters is the easiest solution plus should nt make that much difference to ratio.
when you find the answer i'll be interested....
