| Home > Help Needed / General Tech Chat > Clutch hot spots, pictures inside | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
8th Aug, 2010 at 05:50:31pm
I have just had to partly strip a freshly built engine (with only 50 miles on it) to sort a gearbox issue and have now had a new bush fitted to the primary gear due to it sweating oil slightly.
8th Aug, 2010 at 07:01:57pm
What pressure plate is that? looks new? and what is the spec of your new engine?
8th Aug, 2010 at 07:05:58pm
Mine is exactly the same. I slapped it back on and its fine. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Aug, 2010 at 07:07:48pm
On 8th Aug, 2010 matty said:
Mine is exactly the same. I slapped it back on and its fine. ![]() I am just anal
8th Aug, 2010 at 07:31:49pm
Mine is exactly the same. I slapped it back on and its fine. ![]() Fair enough, i have just applied engineers blue to the surface and turned the friction plate on it and it had scratched it on the non discoloured parts so i assume the plate is contacting uniformly. It's a new AP pressure plate sprocket, the type with the riveted ring on the back side of it. sorted, cheers |
8th Aug, 2010 at 08:14:28pm
There is more than one AP pressure plate, with differing clamping forces, that is what I was trying to get at.
9th Aug, 2010 at 01:21:55am
my mistake, it's a 190mm valeo kit that i'm running, from minispares. http://www.minispares.com/Product.aspx?ty=...=0&tc=1#submenu |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Aug, 2010 at 09:27:28pm
Mine was far worse than that after last years outing at castle coombe, persivered with it untill recently. skimmed it which left a few high spots, the judder is very minimal on take up. Id put it back in.
61 Posts Member #: 8970 Advanced Member shropshire |
13th Aug, 2010 at 09:37:36pm
is the rest new ie rod and slave i had one that had worn causing same sort of prob i changed them to solve my prob |
14th Aug, 2010 at 01:51:11am
Yea the rest of the assembly was new also. It's running fine after refitting so i'm leaving it |
