Home > Help Needed / General Tech Chat > ecu carb connection
minib
Member #: 7138
hi guys got the car running and took it out for a spin, its ok until the turbo starts to boost and then the engine cuts out i get the impression its fueling as it cuts straight off as the gauge goes past zero. i have been sat thinking and remembered i never blocked off the ecu pipe from the carb could this be causing this problem.
thanks.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
any vent to the float bowl prevent it to be pressurised, so fuell can't escape anymore in carb jet, I prefer to T here some boost signal from the plendimonium
minib
Member #: 7138
thanks for the help thought it must be that ill t into the pressure from the plenum chamber thanks again
steve
