| Home > Beginners Tech > Turbo distributor identification? | |||||||
50 Posts Member #: 9008 Advanced Member Lancashire |
10th Aug, 2010 at 12:43:53pm
I'm looking for a genuine turbo distributor but having never seen one, makes the task a little tricky. How do you tell one apart from standard types? They must have identifiable characteristics or serial numbers etc. |
10th Aug, 2010 at 03:51:34pm
ID No. 41932 stamped on the side of the Dizzi 1982-84 this type has the seperate ignition module which when fitted to the metro is mounted on the clutch bell housing.
Own the day
10th Aug, 2010 at 05:41:58pm
Thanks for reply, so there's three types. Are they all the same or do they have different curves? Is there one that's better or worse than the rest or is it just different numbers? Thanks again. |
10th Aug, 2010 at 05:46:10pm
The advance curves are the same on all. The later type with the module mounted on the side is certainly a neater install. |
