| Home > General Chat > Leaky garage roof | |||||||
10th Aug, 2010 at 03:19:01pm
Ive got one of the old style prefab garages with the asbestos corrigated roofs and its starting bloody leaking!
10th Aug, 2010 at 03:26:49pm
depends how much of a bodge you want todo, fibreglass usually works well On 15th May, 2009 TurboDave said:
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
10th Aug, 2010 at 03:46:27pm
we have the same type of garage with the same problem. a bit of expanding foam fixed it for us. |
10th Aug, 2010 at 03:55:16pm
Yep I fixed mine with expanding foam and underseal, both of which I had handy at the time and it worked a treat untill I replaced it. http://www.twin-turbo.co.uk
10th Aug, 2010 at 03:58:22pm
Expanding foam it is then. Did you apply it to the inside or out? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Aug, 2010 at 05:12:55pm
it might not be asbestos might be pressed concrete they look the same Crystal Sound Audio said:
10th Aug, 2010 at 05:58:39pm
how old is the roof? these normally split along the position of the fixings and these can be the point of ingress.
10th Aug, 2010 at 06:44:02pm
On 10th Aug, 2010 matty said:
Expanding foam it is then. Did you apply it to the inside or out? http://www.twin-turbo.co.uk
11th Aug, 2010 at 07:49:49pm
My house was built in the 50's so more than likely absestos!
11th Aug, 2010 at 09:51:03pm
acropol is brush on - you should get it or an equivalent from the builders merchants |
12th Aug, 2010 at 07:49:20am
If you have the budget - just lay a new plastic coated steel roof on top of the old one. As good as re-roofing withou the hassle of getting rid of (or disturbing) the asbestos. |
12th Aug, 2010 at 08:04:31am
I have used this on my garage to replace the asbestos.
12th Aug, 2010 at 02:57:37pm
thats not a bad price Ben - only issue you have is correctly disposing the asbestos sheet |
12th Aug, 2010 at 03:03:22pm
If the profile matches you don't need to remove the old. |
12th Aug, 2010 at 06:39:39pm
The profile won't match. Getting rid of my asbestos was very easy. I rang up the council who sent me a permit and I took it down to the tip. It is very easy. http://www.twin-turbo.co.uk
