| Home > Help Needed / General Tech Chat > just a quick few Q's | |||||||
15 Posts Member #: 9002 Member leicester unfortunately |
11th Aug, 2010 at 01:27:32pm
im going for a mirage mani
11th Aug, 2010 at 05:47:29pm
you can get 18cc accralite +0.020 pistons for less than that. Have a look at avonbar's website.
11th Aug, 2010 at 05:52:09pm
hi there creding mirage fine, the T25 fine but i would opt for a GT17 off the sarb 95
11th Aug, 2010 at 05:54:29pm
forgot to mention ... the omega pistons are great!! but........... for £100 less you can get accralites and in all my engine builds i use these with no problems todate they are a higher spec piston.
11th Aug, 2010 at 08:12:51pm
For 100 bhp I really wouldn't bother with the expense of a forged piston, the cast Omega will be more than up to the job. |
![]() 465 Posts Member #: 1972 Senior Member Worcester |
11th Aug, 2010 at 08:29:53pm
I think you will be disapointed with the 200sx t25 especially at low boost for 100bhp. It wont boost until 4000 rpm with the massive .64 exhaust housing, and feels quite laggy, ive just took one off my car and switched to something more modern. |
12th Aug, 2010 at 10:56:58am
Cheers for all the replys.
12th Aug, 2010 at 11:20:38am
If you are going to fit a different turbo, lower the compresion ratrio and add an intercooler then chances are the advance curve of the metro turbo dizzy won't be suitable for your engine. Presonally, I would look into using megajolt.
12th Aug, 2010 at 12:49:51pm
Why do you need 18cc's in the piston?
In the 13's at last!.. Just |
12th Aug, 2010 at 02:23:33pm
cheers ever one im not sure about the 18cc which is why im askin i just keep seeing lower CR :s
st/ mani ?
