| Home > Help Needed / General Tech Chat > dry decking advice | |||||||
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
11th Aug, 2010 at 02:42:47pm
I was reading all the threats about dry decking...... and im puzzeld..:)
11th Aug, 2010 at 02:51:47pm
All depends what you plan todo with your engine, whats the spec on it so far? On 15th May, 2009 TurboDave said:
11th Aug, 2010 at 04:01:33pm
1293 cc , deepdish omegas, phase2, head with 32 cc chambers, bronze valveguides, bigger ilnlet valves ,gt1752 turbo ,dumpvalve, , crankshaft nitrated ,balanced, ultralight flywheel, grey clutch, megajolt.....and all the rest i forget at the moment :) |
11th Aug, 2010 at 05:45:53pm
How far have you skimmed the block? If you put plugs etc into the water holes, you'd need to get the blocked skimmed again. If you've decked flush with the pistons, then you probably can't skim any further Edited by apbellamy on 11th Aug, 2010. On 11th Feb, 2015 robert said:
11th Aug, 2010 at 06:50:59pm
as far as i can see i cant skim any further..is ther a way to put in tapperd plugs then? |
11th Aug, 2010 at 07:23:03pm
You don't have to skim the block again, tap the holes & use grub screws like I did, here: |
12th Aug, 2010 at 10:40:05pm
ive done same as phill but mines going for a skim anyway before final build Yes i moved to the darkside |
13th Aug, 2010 at 11:12:08pm
On 11th Aug, 2010 clubbie70 said:
1293 cc , deepdish omegas, phase2, head with 32 cc chambers, bronze valveguides, bigger ilnlet valves ,gt1752 turbo ,dumpvalve, , crankshaft nitrated ,balanced, ultralight flywheel, grey clutch, megajolt.....and all the rest i forget at the moment :) Deep dish Omegas like 18cc?? 5:1 compression might be on the low side? On 13th Jul, 2012 Ben H said:
