Home > Help Needed / General Tech Chat > Auto 1275 Block
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
I was given a 1275 auto mini and just wanted to know what is needed to change this to a manual.
I know that the dipstick needs drilling and that a oil filter has to be fitted to the block
Can this be drilled like the standard block for a fair price or can it be mounted else were?
Also does anything else need doing to the engine block that i have missed?
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
You need to make an adaptor plate up to fit a 'normal' oil pump. Drill out a gallery where the PRV is. And blank off another gallery. There is a 'how to' on one of the Aus forums.
Gaball
Member #: 7169
Somerset, UK
is it worth doing this or less expensive to buy a new block?
Carbon but plug?
depends how skilled you are. Have a search, there is a guide somewhere
You can buy the adapter plates. If you're getting a machinr shop to bore,skim block then I can' imagine they'd charge a great deal to drill a gallery out.
Ive got an Auto block as a spare, worth keeping imo.
dan_up
Member #: 1835
Thame, oxfordshire
and a manual 1275 block matt *wink*
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare
Haha I will pick that up! Let me know when your at the barn next!
