Home > For Sale > MITP engine parts -more parts added!
johnK
Member #: 690
Norfolk
We have a few large lumps of metal that are surplus to our requirements which we'll chuck in the van to take to MITP. If anyone wants to buy the parts we'll put their names on them but they need to be collected before mid day Sunday or we'll put them back up for sale on the day. We'll be there from Sat afternoon so more than welcome to pick them up then.
1275 A+ linered block - we can't make it into 73.5mm hence of no use - looks perfectly servicable with caps £20
block as above - £20
A+ con rod set - £20
Innocenti con rod set - strongest bar the S - £25
BMW 8v throttle bodies only - require a TPS to be fitted for K conversion use rather than the std 8v "switch"- £5
8v ITB'sas above £5
8v ITB'sas above £5
Metro Turbo BRAND NEW GEARBOX - not a recon this is brand new from the factory inc diff - fully built unit - correct casing numbers etc (no nose brg ) - £offers
12g940 head MG valve sizes - £30
940 as above - £30
940 as above - £30
940 as above - £30
940 as above - £30
12g940 small valves - £25
12g940 mg valve sizes - bare - light porting £20
(we will have more heads - I'll post them up in another mail)
Mg rocker box - good std cond - £5
MG rockerbox as a bove - £5
Yamaha R1 bike carbs, just before FI, position for TPS (not fitted) - £50
HS2? - 1 1/4 - £5
HS4 - 1 1/2 - £5
HIF38 1 1/2 - £10
JK
Edited by johnK on 12th Aug, 2010.
If Carling made Mini engines
longy
Member #: 2727
Bicester
can i have dibs on the 12g940 MG head, im not going to be at MITP but i can arrange someone to pick it up for me
1972 998 TURBO SLEEPER
retroracer1380
Member #: 1972
Worcester
il take the block or blocks if theres 2 for £20 each please
Edited by retroracer1380 on 12th Aug, 2010.
johnK
Member #: 690
Norfolk
1275 A+ linered block - we can't make it into 73.5mm hence of no use - looks perfectly servicable with caps £20 -RETRORACER
8v ITB'sas above £5
8v ITB'sas above £5
12g940 head MG valve sizes - £30 -LONGY
940 as above - £30
940 as above - £30
cheers
johnK
Member #: 690
Norfolk
block as above - £20 -RETRORACER
8v ITB'sas above £5
8v ITB'sas above £5
940 as above - £30
940 as above - £30
cheers
Mr Joshua
Member #: 1954
Luton Bedfordshire
Ill take one of the 12g940 heads with the MG vales fitted
Own the day
I have some wheels for retroracer1380, can we use your stall as a meeting place John :)
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Ill take one of the blocks if Retroracer doesn't have both in the end
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
johnK
Member #: 690
Norfolk
Hi Joe - of course you can - see you Sunday!
8v ITB'sas above £5
8v ITB'sas above £5
940 as above - £30 -Mr Joshua
940 as above - £30
cheers
Put me down for a head.
will have a 12g940 if this is ok
johnK
Member #: 690
Norfolk
1275 A+ linered block - we can't make it into 73.5mm hence of no use - looks perfectly servicable with caps £20 RETRORACER
block as above - £20 RETRORACER
8v ITB'sas above £5
8v ITB'sas above £5
12g940 head MG valve sizes - £30 LONGY
940 as above - £30 MR JOSHUA
940 as above - £30 MADMK1
940 as above - £30 JOHN
940 as above - £30
HS2? - 1 1/4 - £5
HS4 - 1 1/2 - £5
HIF38 1 1/2 - £10
Can I have a rocker cover please John.
I might be a bit later than 12 though.
minipete
Member #: 1890
Driffield East Yorks
Are the innocenti rods still availible?
East Yorkshire Mini Owners Club.
www.miniowners.freeserve.co.uk
johnK
Member #: 690
Norfolk
8v ITB'sas above £5
8v ITB'sas above £5
940 as above - £30
Mg rocker box - good std cond - £5 ONEEYELIZARD
HS2? - 1 1/4 - £5
HS4 - 1 1/2 - £5
HIF38 1 1/2 - £10
ok oneeyelizard names on the cover
I'll take these please John.
Can I have the innocenti rods if pete doesnt want them
retroracer1380
Member #: 1972
Worcester
Good plan!
johnK
Member #: 690
Norfolk
Innocenti con rod set - strongest bar the S - £25 -PETE
8v ITB'sas above £5
8v ITB'sas above £5
940 as above - £30
12g940 small valves - £25 -TURBOPHIL
12g940 mg valve sizes - bare - light porting £20 TURBOPHIL
MG rockerbox as a bove - £5 TURBOPHIL
HS2? - 1 1/4 - £5
HS4 - 1 1/2 - £5
HIF38 1 1/2 - £10
Sorry Nic - he just pipped you!
I'll take a set of A+ conrods. John will collect them along with his head and pay for them as I won't be there. (John - money will be in the van's glove box. ta)
johnK
Member #: 690
Norfolk
A+ con rod set - £20 JOHN
8v ITB'sas above £5
8v ITB'sas above £5
940 as above - £30
HS2? - 1 1/4 - £5
HS4 - 1 1/2 - £5
HIF38 1 1/2 - £10
thats no problem thanks Apbellamy
kcchan
Member #: 8853
Pm'd about r1 carbs
John I'll be picking Chris' (longys) head up for him at MITP. Just incase he hasn't got in touch with you!
