Home > Wanted > Ignition switch plug?
dischub
Member #: 8143
London
Is anyone cutting up a loom? I need the connector for the thing shown in the pic which is part of the ignition switch barrel
Edited by dischub on 16th Aug, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
If my memory serves, the plug that this connects to is itself at one end of a short length of 4 wires that goes to the black plastic ignition switch barrel, usually held into the ali switch housing with a tiny single self tapper.
I have about three of these if you need this stuby loom and plastic switch thingy or are you just after the connector block and a length of each of the 4 wires from the plastic switch ?
Either way, I can sort u out with the connector and the wires Rahul if you need me to.
Couple of quid to post.
Richard.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Have sent you a PM Rahul.
Richard.
