| Home > Help Needed / General Tech Chat > 1984 MG Metro Turbo - Advice appreciated | |||||||
7 Posts Member #: 8445 Junior Member |
16th Aug, 2010 at 12:35:06pm
I have a 1984 MG metro turbo that I have just completed some body repairs to. Getting it back on the road there is a loss of power/inability to rev beyond 4000.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
16th Aug, 2010 at 12:52:30pm
Is it not advancing? vac pipe disconnected? |
16th Aug, 2010 at 12:53:39pm
16th Aug, 2010 at 03:21:02pm
Thanks for the advice so far. Am confident that ECU is connected as LED boost gauge is working on the dash. Also distributor is connected bt will check as is advancing by putting acuum pump on it. |
16th Aug, 2010 at 06:47:45pm
16th Aug, 2010 at 08:36:56pm
All, thanks for the replies so far. Checkede dizzy, seems fine. Felt like a fuel issue so pulled choke out and it picked up and went like the clappers. So took top of carb and blew through the jet into carb and then from chamber to jet. Put it back together and now seems to run really well. Haven't got a rear section for the exhaust so can't try it fully but so far so good. Thanks again everyone. |
16th Aug, 2010 at 11:54:54pm
well done you! |
17th Aug, 2010 at 08:08:42am
Welcome to TM Martin! Hope you like it here. If something is worth doing, it's worth doing half of. |
Have you checked the little ecu is still connected and working. It controls boost and gives you the signal for the LEDs on the dash.
