| Home > Help Needed / General Tech Chat > Ignition connections | |||||||
![]() 323 Posts Member #: 41 Senior Member |
9th Nov, 2003 at 04:30:12pm
does anyone know where the black wire on the ignition pack go to? i know there is the neg and pos connections that go to the coil, just cant remember where the black one goes!? have a feeling it goes to the ECU originally?? any help muchos appreciated A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
11th Nov, 2003 at 08:39:02am
not sure what you mean.. all the ign pack I have seen are two wires... and just st8 onto the coil...
AlexF |
13th Nov, 2003 at 05:48:23pm
see if this works....
14th Nov, 2003 at 08:18:20am
hmmm never seen one of those lol
AlexF |
14th Nov, 2003 at 08:43:11am
There is two types of turbo dizzy. Both of which ive had.
14th Nov, 2003 at 09:46:42am
I used my std mg dissy at 0.5 bar of boost!!!
AlexF |
15th Nov, 2003 at 04:37:49pm
thanks for the help guys. if i were to use the Mk1 as in the picture, does it need to be bolted to anything metal? as it was connected to the radiator/fan bracket when i got the engine. also if you could find out where that black wire goes iain that would be a great help. i think it would work on the two normal pos and neg wires A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
15th Nov, 2003 at 06:59:52pm
Ill check the connections tomorrow.
15th Nov, 2003 at 07:57:30pm
cheers m8, i'll fabricate something to mount it on A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
54 Posts Member #: 64 Advanced Member |
27th Nov, 2003 at 06:57:25pm
28th Nov, 2003 at 07:43:45am
Ive had a look at mine and cant quite figure it out at the minute! Hmm bit of a strange one though. Its only the same module as used on the later cars so it cant do much. Id just try it and see what happens. |
