| Home > Help Needed / General Tech Chat > bottom supercharger pulley | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
16th Aug, 2010 at 03:34:54pm
what tools and how difficult is it to remove the bottom pulley, and swap it for a supercharger one? like jonspeed or are there any alternatives? |
16th Aug, 2010 at 03:37:56pm
Lock your engine, knock back the lock tab and undo the big nut. Then just slide the pulley of.
16th Aug, 2010 at 03:42:19pm
lock the engine do you mean put it in gear?
16th Aug, 2010 at 05:03:40pm
you need to stop the crank from rotating or you won't be able to undo the big nut. I usually put and old crank shell into the flywheel ring gear teeth in the starter hole. If you just put it in gear it will probably just roll the car forwards/backwards.
16th Aug, 2010 at 08:36:47pm
APbellamy I love the "Just slide it Off"... not my first experience I run a supercharger and I don't care the TB is on the wrong side.
16th Aug, 2010 at 08:57:32pm
I use a brass drift and BFH to assist with the sliding when necesary On 11th Feb, 2015 robert said:
17th Aug, 2010 at 10:25:46am
when you say an old crank shell into the where the starter motor teeth go does it get lodged in place? |
17th Aug, 2010 at 11:03:10am
The ends sit in the teeth of the ring gear, then you rotate the crank in the direction that you need to undo the bolt. The shell then sits against the transfer case. The shape of the shell is inherantly strong, so it acts as a lock. I put enough force on my flywheel puller to break the big centre bolt recently - the shell didn't budge. On 11th Feb, 2015 robert said:
