| Home > Help Needed / General Tech Chat > Strange misfire problem | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
16th Aug, 2010 at 07:31:07pm
Need a bit of help as ive pickled my brain:
16th Aug, 2010 at 07:32:17pm
16th Aug, 2010 at 08:30:36pm
Just tried wiggling all the wires, but not made any difference. At idle if i take the leads of cylinders 1 and 2, it makes no difference to the rough running. But when you rev it up and you do the same and you take the leads off it noticeably drops a cylinder.
Edited by retroracer1380 on 16th Aug, 2010. |
16th Aug, 2010 at 08:35:01pm
checked for a leak on the manifold gasket? give it a blast with carb cleaner and see if it picks up. On 20th Oct, 2015 Tom Fenton said:
16th Aug, 2010 at 09:01:45pm
I'm going to say do a leak down test,
16th Aug, 2010 at 10:00:43pm
my guess is same as joe C
17th Aug, 2010 at 12:09:25pm
Cheers all for the ideas, cant beleive i overlooked the manifold gasket! Cheers Nick, just gave it a spray with clutch and brake and it runs smoother, im guessing where the carb has been hiting the bulkhead it has disturbed the seal.
18th Aug, 2010 at 02:57:23am
GinoR32 had the exact same problem, he did all you did and it turned out to be an air leak on the inlet manifold due to a broken gasket Own the day
18th Aug, 2010 at 04:41:49pm
Lol, at least its a simple fix! |
