| Home > Help Needed / General Tech Chat > GT17 down pipe help | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
16th Aug, 2010 at 11:03:25pm
I am about to purchase the rest of the bits for my down pipe, and was wondering what the best method was to clamp the pipe to the turbo was? i have done a bit of searching but i cant find and good info on what style of flange was preferred? (shaven or just trimmed?)
![]() 465 Posts Member #: 1972 Senior Member Worcester |
17th Aug, 2010 at 12:21:25pm
I used a flare of an old exhaust pipe, trimmed it to fit, then warmed the flare up and hammered itaround on the exhaust housing to fit perfectly.
17th Aug, 2010 at 03:03:05pm
was the flange flared aswell? |
17th Aug, 2010 at 03:20:53pm
Cheers, was the flange flared aswell? |
17th Aug, 2010 at 04:00:21pm
I made the flange out of solid plate, i think i put a slight chamfer on it, but as i welded it to the pipe it didnt really matter. Il try and get a pic later if you like |
17th Aug, 2010 at 10:07:31pm
pictures are always helpful but i get the jist of how you have done it Thanks.
17th Aug, 2010 at 10:37:18pm
On 17th Aug, 2010 maccamcvey said:
pictures are always helpful but i get the jist of how you have done it Thanks. Has any one els done it differently? Cheers Yes I had a flange lazer cut and a bush machined with a 45 degree taper to take 2.25" tube. On 26th Oct, 2004 TurboDave16v said:
17th Aug, 2010 at 10:46:23pm
On 17th Aug, 2010 Sprocket said:
I had a flange lazer cut and a bush machined with a 45 degree taper to take 2.25" tube. How much did that rush ya? |
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
17th Aug, 2010 at 10:49:35pm
I got hold of a Saab downpipe, cut the 90' bend off it before the cat. Just got to weld it to a metro turbo downpipe. Perfect seal to the turbo, as its the factory item! On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
17th Aug, 2010 at 11:01:17pm
I had a flange lazer cut and a bush machined with a 45 degree taper to take 2.25" tube. How much did that rush ya? Cant remember, I got them done with a load of other stuff. Certainly is not as cheap as shaping a taper in 1.5mm stainless and welding it onto the down pipe. Just think that it will give a better fixing. On 26th Oct, 2004 TurboDave16v said:
17th Aug, 2010 at 11:40:41pm
cheers guys |
