| Home > General Chat > Cryo Treatment underway! | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
17th Aug, 2010 at 02:50:47pm
so lads.
17th Aug, 2010 at 02:53:26pm
I believe JohnK has done the block and box for his twin-k tubby. If something is worth doing, it's worth doing half of. |
17th Aug, 2010 at 03:03:50pm
What's the cost like over there? On 11th Feb, 2015 robert said:
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
17th Aug, 2010 at 03:15:28pm
We shouldve done a hardness test on them before you sent them Nick. See if it makes a quantifiable difference. Or does anyone else have data for it? In boost we trust |
17th Aug, 2010 at 03:40:34pm
ah good thinking joe! we so should have done that!!! to late now, it's in the hands of the post man. :)
Edited by NickG on 17th Aug, 2010. |
17th Aug, 2010 at 03:42:05pm
On 17th Aug, 2010 apbellamy said:
What's the cost like over there? about 50 pounds to do all the GBox internals |
17th Aug, 2010 at 03:53:41pm
Bargain If something is worth doing, it's worth doing half of. |
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
17th Aug, 2010 at 05:08:44pm
i suppose the only way you'll know if they have been done is if they feel colder when they return.lol
17th Aug, 2010 at 05:32:59pm
17th Aug, 2010 at 05:44:34pm
17th Aug, 2010 at 07:04:43pm
Or
17th Aug, 2010 at 07:06:18pm
A hardness test will tell you nothing.
17th Aug, 2010 at 07:11:26pm
I thought that at first but never said anything as Im not really clever enough to fully understand it and give such a reply On 26th Oct, 2004 TurboDave16v said:
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
17th Aug, 2010 at 10:18:12pm
what is it liquid nitrogen?
17th Aug, 2010 at 10:31:09pm
I was under the impression (and I could be WAAAAYYY off the mark here).
17th Aug, 2010 at 10:34:20pm
its all to do with the crystaline structure of the metal. On 26th Oct, 2004 TurboDave16v said:
18th Aug, 2010 at 02:38:41am
i read alot of racer guys cry gen there gears then shot peen.
Edited by NickG on 18th Aug, 2010. |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
18th Aug, 2010 at 05:48:47am
I have very little knowlege on cryo treatments altho i`ve had it done to some cranks
www.miniman.com.au
19th Aug, 2010 at 01:39:52pm
Wikipedia pretty much says you heat treat them temper it all the way down -lots, as an extension to the process.
In boost we trust |
19th Aug, 2010 at 06:46:50pm
http://www.195below.co.uk/Pages/Science.html On 26th Oct, 2004 TurboDave16v said:
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
19th Aug, 2010 at 08:44:08pm
On 17th Aug, 2010 SumpNut said:
I was under the impression (and I could be WAAAAYYY off the mark here). That the treatment is in some ways similar to shot peening. They cool the sample so rapidly the top layers of the material cool and contract at a greater speed than the core, leading to some sort of compressive forces on/near the surface that remains onces it is slowly brought back upto room temp. Surely if the top layer contracts more than the interior it must be in tension, not compression. It would be the inner part which is in compression. Geoff |
19th Aug, 2010 at 11:06:51pm
I was under the impression (and I could be WAAAAYYY off the mark here). That the treatment is in some ways similar to shot peening. They cool the sample so rapidly the top layers of the material cool and contract at a greater speed than the core, leading to some sort of compressive forces on/near the surface that remains onces it is slowly brought back upto room temp. Surely if the top layer contracts more than the interior it must be in tension, not compression. It would be the inner part which is in compression. Just read that From what I read, they slowley cool the parts to ensure that the whole part is the same temperature unlike heat treatment. On 26th Oct, 2004 TurboDave16v said:
