Home > Technical Chat > spi loom
sullyMONSTERmini
Member #: 9028
Hi all just wondering how to set up my spi loom to a metro turbo, im not using an ecu and the engine is going to be running standard with no mods help please
4 posts asking the same question and you've already had an answer...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=378090
sullyMONSTERmini
Member #: 9028
yes but in that post im told i CAN use an spi loom im not told how to set it up as the loom has connections for a cooper spi ecu, i need to know if the loom can b connected up as normal without the ecu and does the engine run the sameor can i use the cooper ecu as the engine is standard.
get a loom from an earlier carbed car. job done.
