| Home > Help Needed / General Tech Chat > hmmmm pumping | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
18th Aug, 2010 at 04:45:58pm
just been thinking and reseraching fuel pumps for supercharger suckthrought setups and am rather confused
18th Aug, 2010 at 05:19:26pm
fuel needs to be boost dependant, i dont see why you dont stick to whats tried and tested spi/mpi tank and turbo reg Crystal Sound Audio said:
18th Aug, 2010 at 05:22:37pm
i didnt know people done that, i thought that the carb will govern the fuel pressure and fuel pump only needed to be rated at bhp |
18th Aug, 2010 at 06:04:40pm
If it is suck through then the carb does not operate under pressure, so a red top or whatever will suffice. Blow through needs the fuel pressure to stay above boost pressure, thus you need a rollervane pump and the correct regulator.
18th Aug, 2010 at 06:39:08pm
I was advised that I need a regulator set for a constant 3.5psi for my suck through setup. On 11th Feb, 2015 robert said:
18th Aug, 2010 at 07:08:59pm
Most of teh low pressure pumps are self regulating to a degree. In that they may only actually be capable o generating say 5psi or so
Edited by stevieturbo on 18th Aug, 2010. 9.85 @ 145mph
21st Aug, 2010 at 05:30:30pm
i have recently sold all my turbo parts including tank and as i am on a very tight budget want to do a supercharger conversion for under 500 pound
21st Aug, 2010 at 05:30:36pm
21st Aug, 2010 at 05:50:57pm
forgive me if im wrong but a particular member had alot of running problems using the cheapo adjustable fuel pressure regulator
Yes i moved to the darkside |
21st Aug, 2010 at 05:51:59pm
No. A piece of shit egay regulator intended for a high pressure fuel injected engine will not do.
21st Aug, 2010 at 08:48:00pm
I run a 3 psi Facet solid state for my bike carb suck through. I would just match it to the carb you are going to use. I run a supercharger and I don't care the TB is on the wrong side.
22nd Aug, 2010 at 12:21:39pm
i have a 40 webber now but will upgrade to the 45,
22nd Aug, 2010 at 12:21:45pm
