Page: |
Home > Show Us Yours! > astra 1.4 8valve lpg turbo. | |||||||
6744 Posts Member #: 828 Post Whore uranus |
2nd Nov, 2012 at 07:49:48am
thats good news jean , thank you , i read about the 2amp stuff in here ..
Edited by robert on 2nd Nov, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Nov, 2012 at 08:09:18am
Robert,
Edited by Rod S on 2nd Nov, 2012. Schrödinger's cat - so which one am I ??? |
2nd Nov, 2012 at 02:19:33pm
I agree with Rod about the resistors.
2nd Nov, 2012 at 05:18:27pm
gosh chaps ,very kind of you rod ,and thanks jean for the data on values . what i will do is try with the 3 ohms ,and if that doesnt work ,give your bits a try rod .
2nd Nov, 2012 at 06:05:12pm
ok 4 of these bad boys on the way ..
2nd Nov, 2012 at 06:22:18pm
oh yeah!
6th Nov, 2012 at 06:54:15pm
I just had someone posting the specs on my forum for the new Valtek type 34 and they are much better suited for my P&H drivers: http://forum.jbperf.com/download/file.php?id=262.
7th Nov, 2012 at 07:51:14am
thanks jean , any info relating to the subject is of interest ,and i appreciate the input . they sound a lot lot faste than my ones ...
7th Nov, 2012 at 02:45:23pm
One thing I don't see in your specs is the flow. If your injector flow a lot more than the type 34, they could be physically bigger which would explain why they are slower.
9th Nov, 2012 at 06:59:40pm
good point jean , i only know that the valtek 30 uses a calibtated nozzle for each injector ,that is varied in size depending on bhp requirement , so the inj itslef will flow the max with a 4mm nozzle ,and then it is sized down to a smallest of 2.5mm for lowest power .
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
9th Nov, 2012 at 07:33:31pm
noicely dun ! ( been brushing up on my Englush) That sir, is not rust, it is the progressive mass reduction system
10th Nov, 2012 at 10:46:38am
Robert,
On 7th Nov, 2012 robert said:
2 POWER OF COIL 48 W – 144 W 3 PILOTING TYPE PEAK and HOLD 4 TIME FOR PEAK CURRENT 4,5 ms 6 RESISTANCE 3 Ohm +-4% - 1 Ohm +-4% 12 OPENING TIME 3,3 ms 13 CLOSING TIME 2,2 ms I've even looked up the complete datasheet and it still doesn't entirely make sense.... I can understand why they are quoting two different power ratings as they say they are peak and hold injectors - but I don't understand them quoting two different resistance values... The 1ohm matches a power rating of 144W (providing you assume battery is allways 12V (which it isn't) as 1ohm would draw 12A) but if it's a single coil, it can't have a second, completely different, resistance. I can only assume the 3ohm is an implied resistance when being fed with a lower hold current - either by a P&H drive chip or by PWM - as an implied 3 ohm would equate to 48W at 12V (as 3 ohm would draw 4A). So if the real DC resistance is 1ohm and you wire them in series with an additional 3ohm resistor, they will only draw 3A (or 36W of power) which is less than their hold rating so I honestly doubt if they will ever open. Even if you use 2ohm resistors, you would be trying to open them at 4A (or 48W) which is their hold rating, not their openning rating. Any lower value resistor, I expect they will overheat rapidly... Also line 7 of the datasheet says they are meant for sequential injection. How soon do you intend to try the resistors ??? Schrödinger's cat - so which one am I ??? |
10th Nov, 2012 at 03:37:23pm
Rod,
10th Nov, 2012 at 04:30:28pm
Jean,
10th Nov, 2012 at 05:44:52pm
Well, I can't find something clear but if you look at the information here: http://www.valtek.it/Prodotti/Rail-iniezio...Gpl-Metano.aspx you'll see that the injectors are available with different coil impedance values. What is curious though is that none of the values shown there is 3 Ohm.
10th Nov, 2012 at 06:22:58pm
On 9th Nov, 2012 Sir Yun said:
noicely dun ! ( been brushing up on my Englush) thank you joost , im not even going to start to try brushing up on my dutch ,'shmoke 'nd a pancake' is my limit (sn't that wiiieeerd !?) rod and jean , intersting stuff on the injectors , the resistors i got are 2.7ohm . the chap in the link that used resistors , has injectors that look the same model as mine ,and he used 1 ohm resistors ,which sort of supports what you are saying rod , but then again how come his board or inj don't overheat ? heres that link again rod , in case you did not see it .... http://fuelsforum.rasoenterprises.com/view...t=1062&start=15 Edited by robert on 10th Nov, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Nov, 2012 at 06:57:17pm
Robert, in that link
Edited by Rod S on 10th Nov, 2012. Schrödinger's cat - so which one am I ??? |
10th Nov, 2012 at 07:35:32pm
using a analogue rs meter ,and two digital meters ,one a fluke ,and flickers from 3.1 to 3.0 ohms .
10th Nov, 2012 at 07:48:24pm
these people are selling the 1 and 3 ohms versions , looksl like they are colour coded ..
10th Nov, 2012 at 07:53:26pm
That's interesting. And it seems most people have the 3 Ohm version because I've only seen the red ones (not that I've seen many or any other way than in pictures).
10th Nov, 2012 at 08:18:53pm
i have emailed the chap in the thread using the 1 ohms . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Nov, 2012 at 01:55:50am
As per Jean, a good meter (and backed up by more than one in your case) is enough especially now there seems to be more information confirming that there is more than one version.
11th Nov, 2012 at 08:42:51pm
i wonder if its possible to work out the max safe amps for the ms2 ,from the components specs ?
11th Nov, 2012 at 10:29:21pm
If you have a standard MS2, it only has two channels.
Edited by Rod S on 11th Nov, 2012. Schrödinger's cat - so which one am I ??? |
12th Nov, 2012 at 07:36:37am
thanks rod ,good stuff , it ws built for me ,and has all the bits in it i think ,it definately has all the flyback circuitry in it ,and a full compliment of the heat sink row of transistors .
Edited by robert on 12th Nov, 2012. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Page: |
