| Home > General Chat > 13 inch Mambas | |||||||
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
20th Aug, 2010 at 07:21:21am
I found out that mambas have been remade, and they come in 13s now from here.
In boost we trust |
20th Aug, 2010 at 07:44:22am
i looked at these for lisa's car think there very cool in 12's with wood and pickett arches
![]() 552 Posts Member #: 300 Post Whore Cumbria |
20th Aug, 2010 at 08:18:14am
yep, one of our club members has some on as seen at mitp, i'll upload a pic tonight if no one else does in the meantime. Here for the craic..
20th Aug, 2010 at 09:51:39am
Yep they look really good, I'm sure they're going to be popular. |
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
20th Aug, 2010 at 12:32:24pm
im getting 6x10 ones. the new ones. -07 offset so clear 7.9 brakes. and looks neat. not a bad price and come with centre caps On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
20th Aug, 2010 at 02:55:17pm
I had my eye one these too. In the 13's at last!.. Just |
20th Aug, 2010 at 04:24:38pm
Pah, all 7x 13's with silly of set :( On 28th Aug, 2011 Kean said:
20th Aug, 2010 at 04:39:55pm
Boo! In the 13's at last!.. Just |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
20th Aug, 2010 at 04:47:09pm
On 20th Aug, 2010 Joe C said:
Pah, all 7x 13's with silly of set :( they do other sizes too |
20th Aug, 2010 at 04:52:28pm
20th Aug, 2010 at 04:56:12pm
WHOA! ok. |
20th Aug, 2010 at 08:32:49pm
20th Aug, 2010 at 10:51:09pm
why so high at the front? Yes i moved to the darkside |
20th Aug, 2010 at 11:10:40pm
all new and only moved about 300yards since it was built, needs to settle with use. Here for the craic..
20th Aug, 2010 at 11:20:26pm
It's as low as the hi-lo's will go as well ! |
20th Aug, 2010 at 11:54:28pm
Pmsl! In the 13's at last!.. Just |
21st Aug, 2010 at 07:56:17am
Has it got an engine fitted? My car is lower than that without one... On 11th Feb, 2015 robert said:
21st Aug, 2010 at 08:40:07am
On 21st Aug, 2010 apbellamy said:
Has it got an engine fitted? My car is lower than that without one... yep! Edited by Richspec on 21st Aug, 2010. Here for the craic..
22nd Aug, 2010 at 08:26:31am
you need to modify the hi-los.
22nd Aug, 2010 at 09:41:32am
On 22nd Aug, 2010 wil_h said:
you need to modify the hi-los. They will be seeing a lathe shortly. |
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
22nd Aug, 2010 at 10:36:51am
Are they not JBW wheels and MWS are just a supplier of them? |
22nd Aug, 2010 at 02:27:12pm
you need to modify the hi-los. They will be seeing a lathe shortly. Ohhh lathe is is posh boy, I used a hack saw and a file. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
22nd Aug, 2010 at 06:50:56pm
I've just bought the 6x12's, saved about £25 by getting them at MITP.
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
23rd Aug, 2010 at 01:50:15pm
Its still a toss up between 10s and 13s. Theyre going on a 200hp starlet engined rally mini. So going to be spinning rather quickly and used off road. Guess the thicker rubber of 10s would be better then. In boost we trust |
23rd Aug, 2010 at 02:52:49pm
If it's going to be used for rallying then 13s are the better choice. Simply because i bet there is a wider choice of ruber.
