Home > Help Needed / General Tech Chat > blocking original dump valve in the plenum
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
hi there!
What is the best way of blocking original dump valve in the plenum?
any advice or pictures how you done it?? :)
thank you
Nothing special!
Nick
Member #: 154
Midlands
mines been filled with 5p's for years
chominsh
Member #: 8160
I am running an aftermarket dump valve and had advice to block original one in the plenum.
because when i drive 40 mils my tacho shows 5000 on tacho and it saunds that there is air leak :(
I just wondering how to block it?
Nothing special!
Look above. Nick is suggesting you fill it with 5 pence pieces.
Alternatively you could get it welded or chop that piece of the plunundulum off and fit a blanking plate.
I've just got a bolt though the hole on mine with a big washer & loctite on either side. Been fine for 10+ years.
run a 3/8" BSP tad down the hole an use a taperd hex blank, job done!
the hole size is a shade! larger than nominal, but you get some decent threads more than enough to hold that tiny amount of psi
chominsh
Member #: 8160
5 pence piece? nice :) counldn't imagine that *happy*
thank you!!
Nothing special!
Nick
Member #: 154
Midlands
about 75p worth of 5p's *wink*
