Home > Help Needed / General Tech Chat > can i use rubber fuel lines? and valve + valve spring recomendations!
miniboy001
Member #: 8367
bucks
for the feed and return fuel lines could i use a rubber line instead of a copper line and just use the copper for the connections to the pump etc? or will the rubber be no good? it will be running inside the car!
also i am about to order my new valves and springs what would you recomened for a turbo head!? double valve springs? and what size valves? and i suppose bronze valve guides.
also could anyone tell me what big end shell caps i need for my turbo crank!? http://www.minispares.com/Search.aspx
thanks ben
Standard turbo valves and springs work well.
And you can use suitable rubber hose for fuel lines to attach any hardline tubes to the carb or FPR within the engine compartment or underneath or around the tank.
Rubber fuel lines should never be used in the cabin. And I wont admit to ever being as stupid to use them in my own car lol
Although they did work fine. They can tend to stink of fuel though. Young and naive and all that.
Hardline or teflon braided in the cabin only. Nothing else.
Big end bearings are all the same. It's only the turbo bottom half mains that are different being a flat shell
The valves need to be the correct size for whatever size the seats in the head are. As you're fitting new guides the seats will need recutting anyway. But if you're increasing the valve sizes the head will need porting to suit to get the most from them.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
The valve size question was already answered in your other thred, mini spares doing race valves you mite want to get these
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
miniboy001
Member #: 8367
bucks
ok i have gone for the 35.7mm inlet and 31mm exhaust and just to make sure, the valves on the turbo head are 3.57" long!?
Gaball
Member #: 7169
Somerset, UK
Measure your old ones
And that Wong leave much metal between the valves mire likely to crack?
Carbon but plug?
miniboy001
Member #: 8367
bucks
i havent got any old ones i recieved the head with no valves! okay maybe i will go for 29mm then!
It would make a lot more sense to give your head to someone with experience and ability.
Then say "here is my head, can you please install valves and springs that are suitable for my turbo engine"
miniboy001
Member #: 8367
bucks
im fine with installing the valves and springs its just chosen what ones to go in as i am fairly new to the mini scene so i need to know what ones to go for and what ones to avoid! i can put them in at work.
Gaball
Member #: 7169
Somerset, UK
Mini spares race valves and you have your sizes
Get double valve springs, don't know which ones but mini magazine had a bit on cylinder heads this month or last that covered it
Carbon but plug?
miniboy001
Member #: 8367
bucks
yep i have manage to locate some from a freind standard ones with double valve springs! for free!! :) i spent about 2 hours last night on the head and managed to get two ports clean and smooth! may as well save some money and do it myself!! seeing as apprentice pay is s**t.
Johnny
Member #: 6926
Accrington
be careful with doing cheap mods, i am a 3rd year apprentice now, but when i started on turbo-ing my mini i made mistakes buy doing things on the cheap and as a result i broke a 3k engine within 300miles. (all new parts). so had to rebuy it all again. then that only lasted 6k miles and broke because it was detonating. i should have got megajolt and a wideband afr! (was running 9psi). basically the moral of the story is dont set a deadline and rush to complete the car and make sure you get suitable components for the job. not that your not doing things right but turbo phill and benross do head work on here so i would liten to their comments on the subject :) hope all goes well with the build and look forward to seeing the finished article.
Edited by Johnny on 22nd Aug, 2010.
miniboy001
Member #: 8367
bucks
yeah i am looking at getting the engine built then installing megajolt when i have the money and i was looking at this afr gauge http://cgi.ebay.co.uk/AEM-UEGO-Lambda-Wide...les_CarParts_SM. yeah i have been looking closely at what turbophil and benross say! i am a second year now so not far behind you, do you have a apprenticeship or are you just college?
Gaball
Member #: 7169
Somerset, UK
don't polish your inlets!!
Carbon but plug?
miniboy001
Member #: 8367
bucks
i havent polished any just sanded them to get rid of the build up of crap! out of intrest why would you not polish the inlets?
