Home > General Chat > Anyone who has rebuilt/or about to rebuild a turbo carb please help
retro-racer
Member #: 7907
Thame, Oxfordshire.
I bought a turbo carb from ebay which came with out the throttle Assembly, which i didn't think was a problem as most of it is included in the rebuild kit (spindle, butterfly and seals) and i have a N/A HIF 44 that i could use parts from(springs etc).
however after reading the rebuild guide on here i see that the turbo carbs came with two white nylon washers on either side of the throttle shaft.
do they go on top of the seals?? and am i right with this assumption??
I only ask as i rang burlen fuel systems to try and order some and explained that to them and they don't seem to think that they came with them or know what i was talking about.
can i rebuild my carb without them? i guess that they are there to hold the seal in place under boost??
does anyone happen to have anything spare or a usless carb they wouldn't mind selling me etc.
or has anyone got the dimensions of them and a photo?
sorry about all the questions my carb is nearly rebuilt appart from this.
Amp
Member #: 7856
I've had this before with Burlen, they weren't in the original drawings so they won't know what your talking about!
I got some nylon washers and just made them a bit smaller so they fit
Flame Red
Member #: 6267
I noticed these weren't on the diagram when I rebuilt mine, I'm not sure what they actually do but I put them back on as they must have some use. I have noticed other parts which are not shown on the parts diagram when rebuilding other carbs and usually they can't be bought.
retro-racer
Member #: 7907
Thame, Oxfordshire.
cool thanks for the info, so all turbo carbs seem to have them but like you say when i rang up burlen he said the same thing (not on the original drawing).
i shall just make some then as suggested.
could some one be so kind as to measure theres and give me the thickness and the width.
thanks you
