Home > Help Needed / General Tech Chat > megajolt
miniboy001
Member #: 8367
bucks
does anyone run the Hard cut rev limiter? is it woth buying this or is the standard one fine to use?
thanks ben
blister
Member #: 2590
Croydon
i might get shot down for this but
with megajolt you can adjust it so just put 0 in the cells where you want the rev limitier to cut in
miniboy001
Member #: 8367
bucks
so that would be a no to needing it!?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Retarding the ignition helps, but it is not a perfect rev limiter. I prefer a hard cut.
http://www.twin-turbo.co.uk
metroturbo
Member #: 989
North Yorkshire
You don't need to set any cells to zero. There is a soft cut option where you just enter the revs you want it to operate at, and it will retard the ignition at that point.
Star Mag
Member #: 375
Leicestershire
I use one on mine, works well as you can rev through the soft cut!
imo soft cut might be ok on an n/a as it will rob alot of power but for a turbo motor you need a hard cut really,
miniboy001
Member #: 8367
bucks
i will probaly go for the hardcut then, just to add to the list of the expenditures! thanks for the input!!
It's only 20ish quid. Bargain IMO.
miniboy001
Member #: 8367
bucks
yeah it was 25 i have just ordered megajolt! :) if only my mum knew how much i was spending on this car!
Prawn
Member #: 5232
basingstoke
as said, I run megajolt V4 with the soft cut limiter on my n/a 1380, and it stops it well in it's tracks at 7600rpm, but I can imagine with a turbo it'd easily pull past it
Is the hard cut limiter easy enough to wire into an existing setup?
V4 is really easy. V3 is a bit more awkward, but simple enough.
Anton
Member #: 764
Staffordshire
I used on on my 1380 n/a as the softcut would not stop it.
I made mine and Nick's (both V3) from some veroboard and some resistors dead easy cost me about 4quid IIRC..
It also allows you to use a very getto style launch control.
