| Home > General Chat > low mounted radiator | |||||||
22nd Aug, 2010 at 04:15:19pm
i am considering mounting the radiator really low, the output from the radiator would endup about 8-10 inches below the water pump and the inlet about an inch or so below the pump
Yes i moved to the darkside |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
22nd Aug, 2010 at 04:19:55pm
2 things spring to mind :
Edited by Advantage on 22nd Aug, 2010. Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
22nd Aug, 2010 at 05:02:48pm
If you look at mine it's quite low - not as low as you are suggesting - but still well below the thermostat housing.
22nd Aug, 2010 at 05:32:25pm
yeah thats a good way at looking at it Rod, i think im going to have a slow read over your build thread as i remember you put alot of thought into it, Yes i moved to the darkside |
22nd Aug, 2010 at 05:36:54pm
The rad on my Sabre Sprint is even lower than you are planning. There is a header tank from a Metro mounted on the equivalent of the top of the crossmember on the bulkhead (if that makes sense).
22nd Aug, 2010 at 06:26:03pm
The top of the water system will be little different regardless of where the bottom of the rad is. Therefore the pump will see more or less the same head of water so no pumping issues.
http://www.twin-turbo.co.uk
