Home > General Chat > Anyone felt wheezy after welding?
lockfast
Member #: 2775
Aberdeen
I have been doing some welding on my car today and yesterday and I now have an anoying wheeze / tickle in my chest! The only thing I can relate it to is the welding, are any of the fumes produced likely to cause this or is it just a coinsidence? It is not sore it is just anoying that I cant clear it. Has anyone else had this? Is there anything I can do to avoid it?
welding fumes can cause issues,
I've had chest pains before from welding, that zinc coating on sheet steel is supposed to be not that nice.
lockfast
Member #: 2775
Aberdeen
I have been using weld through zinc primer. Might stop that and see how I get on
Edited by lockfast on 22nd Aug, 2010.
Inhaling zinc is not very good for you.
I've come across air feed welding masks before and I'd definitely consider one if I ever have to do another big welding session.
last year i read a very frightening article about the effects of solvent cleaner and heat from welding, apparently it has something to do with Phosgene gas,
very nasty stuff.
lockfast
Member #: 2775
Aberdeen
Thats what I am a little worried about, my car was last painted in 2k. I know it is dangerous stuff to paint with but what about when it starts burning due to the heat from welding
Yo-Han
Member #: 3228
North of the Netherlands
Fumes from welding galvanised surfaces can cause all kind of things, even blindness.
I always remove zinc coating before welding, don't know about the weld through primer though.
Edit: spelling
Edited by Yo-Han on 22nd Aug, 2010.
Dazed and Confused....
mini93
Member #: 2017
Warwick.
when i was in college my materials lecturer was loopy from constand welding for decades....he was the absolute bizz at it still, just used to be a tad strange n all
David.
Johnny
Member #: 6926
Accrington
welding can cause asma, lunch disease and all sorts of nasty shit! make sure you have an extractor or air fed mask! or even just a mask lol but its very dangerous stuff. i was 12 when i started welding and diddnt know about the effects of it, and i had asma for 4 years and still do slightly and i was only welding a little here and there but i had no extraction and it was in a tight space. :S
On 22nd Aug, 2010 Johnny said:
lunch disease
is that like the munchies?
Johnny
Member #: 6926
Accrington
haha maybe, my hands type what i think sometimes *tongue* naa supposed to be LUNG *wink*
lockfast
Member #: 2775
Aberdeen
gulp
maccamcvey
Member #: 6673
Worral Sheffield
gulp indeed i have just started welding but doing most of my stuff outside, i imagine a bit of a breeze is as good as a ventilated mask?
Johnny
Member #: 6926
Accrington
if you have breeze thats good but not too good for the gas if its a gas welder. really, ideally you need no wind and an extractor about 1ft away from the welding area
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I'm just scared of the argon as it's dense and can collect in your lungs if your welding overhead.
I also heard that getting an MRI scan can be dangerous if you do a lot of welding due to the amount of metal that can inbed into your skin, eyes etc.
On 7th Nov, 2008 Nic said:
naeJ
m
maccamcvey
Member #: 6673
Worral Sheffield
pretty sure its not dangerous about the MRI scan just will muck up the results.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Your breathing in O3 or ozone and thats bad thats what is causing your issues.
Own the day
Nick
Member #: 154
Midlands
you'll be fine, i had to get my face X-rayed before i went in the MRI machine just to make sure there was no metal in there.
Jay#2
Member #: 648
At least they checked first, it must have been comforting to know your face wasnt going to come off and bounce around in the MRI unit. *hehe!*
naeJ
m
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Always wheezy after welding...think its due to actually doing some work.
Wheezing just thinking about it!
On 19th Jan, 2010 wil_h said:
bennyy
Member #: 9037
Doncaster, yorkshire
i work in a steel foundary and all the welders wear air tight helmets with respirators and use extractors for this very reason. Not 100% sure what it is but they wear them for a reason *happy*
On 15th Mar, 2012 wil_h said:
